jon – does that mean you ride it at the end of the north loop and end of the south loop – replacing a bit of the fire road that forms the centre of the 'figure of eight'?
You can if you want, it's intended as an end to the north loop. There are long term plans to bypass the fireroad completely on the south loop so the two loops will cross rather than share a section.
For those of you who don't want to ride the logs there are chicken runs around them all. The rest of the woodwork on that section is there to cross ditches and boggy sections (believe me they are boggy, my boots have only just dried out). For those of you complaining it's not natural, er that's rather the point, if you want natural riding then maybe a trail centre's not for you. If it's any consolation the next section we're planning to build will be pretty much straight (with a few corners) singltrack, again removing a long section of boring fireroad so hopefully that'll float a few more boats (except Northwind obviously 😆 , for you there are plans for a loverly new surfaced carpark so you'll be able to ride around in circles to your hearts content).
