I’m a dark side virgin so would appreciate others opinions.
I’ve done some tests rides and worked out what I want, it’s a fairly unexciting Trek Domane, but very happy with the choice and sizing.
I’ve tried the carbon and alu frames, both felt good, but I’m sure the carbon felt very slightly smoother and quicker (maybe psychological).
I originally decided on the 2.0 because that’s bang on the money for cycle 2 work, however I’ve now discovered I can get 50% more cash on the scheme.
For pretty much the same cash I can get a:
carbon frame (with BB90 and E2 headset) + Tiagra groupset + Bonty wheels (look fairly basic)
OR
aluminium frame + (mostly) 105 groupset + Mavic Krysium Equipe S wheels.
It’s a straight choice between:
Domane 4.0
Frame: 400 Series OCLV Carbon, E2, BB90, DuoTrap compatible, IsoSpeed
Fork: Trek IsoSpeed carbon, E2
Wheels: Aluminium hubs w/Bontrager Approved aluminium rims
Tyres: Bontrager R1, 700x25c
Shifters: Shimano Tiagra STI, 10 speed
Front derailleur: Shimano Tiagra, braze-on
Rear derailleur: Shimano Tiagra
Crank: Shimano Tiagra, 50/34 (compact)
Cassette: Shimano Tiagra 12-30, 10 speed
Saddle: Bontrager Affinity 1, steel rails
Seatpost: Bontrager Race Lite, infinite tilt adjustment, 20mm offset
Handlebar: Bontrager Race Blade VR-C, 31.8mm
Stem: Bontrager Race Lite, 31.8mm, 7 degree
Headset: Integrated, cartridge bearings, sealed, aluminium, 1-1/8″ top, 1.5″ bottom
Brakeset: Aluminium dual-pivot brakes w/Shimano Tiagra STI levers
and Domane 2.3 with upgraded wheels:
Frame: 200 Series Alpha Aluminium, IsoSpeed, press-fit BB
Fork: Trek IsoSpeed carbon, SpeedTrap compatible
Wheels: Mavic Krysium Equipe S
Shifters: Shimano 105 STI, 10 speed
Front derailleur: Shimano 105, 31.8mm clamp
Rear derailleur: Shimano 105
Crank: Shimano R565, 50/34 (compact)
Seatpost: Bontrager Carbon, 20mm offset
Handlebar: Bontrager Race VR-C, 31.8mm
Headset: 1-1/8 integrated, semi-cartridge bearings
Brakeset: Shimano 105 brakes w/Shimano 105 STI levers
What do you reckon? Thanks in advance for any advice
