Yeah, you’re running a pretty long fork, I think some of the Enduro boys were running a 150 on the Stumpy.
It’s designed around a 140 fork though. You may be getting a bit too much dive as its starting off pretty talk at the front end.
It’s also a normal’ish BB with a 140 fork, but it’s gonna make your centre of gravity pretty high if you’re sticking an extra 20mm at the front and not raking the front out, or using a pair of offset bushes.
Also, the reach is 435mm with the 140 fork, which is shortish anyway if you’re 6ft, stick a bigger fork on and it’ll probably take that to 430 /425mm.
I’d say try it with the specced fork length to get the geometry back to normal.
Or…. Get a MRP fork, which is 10mm shorter than most other forms in A2C.
I have a 20mm ride bar with 5mm rise stem so that rises it alotish.
Yeah, you’re running the front end very high then.
Cheapest move is to get a cheap flat bar, that’s wider. That’ll give you more effective reach. Then flip and slam the stem. Even more reach, and lower front end.
I’d then maybe just whack in a load of tokens, and run a few less psi in the fork and add some compression damping. Firm up the front end, and drop it a bit.
