About the “give” end, does it feel like an aluminium hardtail? Everybody says that steel HT are much more pleasant when rolling over harsh stuff than aluminium ones (rocks, roots, etc)
Is it also this way in the BFe or is it so overbuilt that you dont get the advantages of the steel?
Renton, nice bike and I’ve got to say how refreshing your honesty is – most post about new bikes don’t have the critical pieces of info.
I’ve been watching your Bfe posts and others, hankering after this kind of build. Years a go I has a Cove stiffee and sold it as it battered me to pieces.
I like my comfort, and am a bit chickensh*t over obstacles and drops, so with your critique about the harder ride you’ve probably saved me building up a frame and throwing money at something I don’t really need.
pese88 – Member
My BFe is very comfortable, a much less harsh ride than my old Alu Hardrock. It’s a more pleasant XC ride than my Reign which while it has the FS cushioning at the back end is harder work to get around on.
Those measurements for the fork suggest you have a 140mm float fitted. IIRC the float can be raised and lowered by installing a plastic spacer – my old float 140’s measured exactly 145mm, so I’m guessing yours have had the spacers removed by the previous owner.
In my experience as a former soul & Bfe owner I’d suggest you also have at least 30mm too many spacers under the stem.
yep and up the grass hill up the back of the house too !!
like I said ive got to get used to it, jumping off the kerb my legs were doing all the wrong things as I was expecting 5 inches of travel to soak it all up !!!!
140mm forks and low bars is spot on for trail riding on my MK2 BFe. If you are looking to change the forks you should definitely consider some travel adjust that go from 100-140. I wind mine down to 95mm when attempting to DJ and ride around the BMX track.
140mm was adequate for riding around in the Peak when I went last. I was plenty comfortable and fast enough downhill, faster than the blokes on their 180mm FS bikes when coming down rocky tech sections. Granted I would have been faster on my FS but I wouldn’t have been so smug.
I’ve only been out on it once and first impressions were really good, but a little let down by the forks, which along with the wheels will be changed in the not too distant future.
Thanks, it’s still a work in progress, but I think it’s a lovely bike. I’ve got the seat dropped there, but it was up and down like a tarts knickers while riding so I think I’m gonna get an uppy-downy seat post! It’s been a while since I had a hardtail and compared to my DH bike it was weird (as expected), but it was certainly fun on anything downhill and picks up speed really well. It was a bit of a slog up-hill but I put that down to my lack of fitness, which will (hopefully) improve. I didn’t notice the front trying to lift, but then I ride with my weight slightly forward (I think).
