Viewing 13 posts - 1 through 13 (of 13 total)
  • New BFe build
  • trickride
    Finally got around to finishing the new BFe build and took it for a short raz aroud! Cannot wait to get stuck in properly. It’s mad fun to throw around, bombproof and although I haven’t weighed it yet – definitely not a heffer.
    getonyourbike
    Lovely. Just needs a dropper post now. You can’t have a BFe, unless it’s a little DJ/4X bike, without a dropper post.
    Scamper
    Nice! I reckon 26.5-27lb for that build, if those are 32’s 😀
    Fresh Goods Friday 696: The Middling Edition
    Fresh Goods Friday 696: The Middlin...
    Latest Singletrack Videos
    winch
    Mmm, good job. 27.5lb is my guess.
    jambalaya
    Very nice … the bike just wants to get up and go
    I_Ache
    Are you mad? Those cranks must weigh 2lbs and those pedals another 1lb. I can’t see that dropping below 29lbs.
    timc
    28.5 my guess
    trickride
    Yeah 32’s on there. Going to have to deliver on the weight now!
    RoganJosh
    Oooooh I reckon 26.74.
    Either that or 27.12 depending on whether that rear tyre is folding or not.
    maurizio
    Very nice indeed! 😀 what travel are you running? Also- ignore the dropper post comments, it’s perfect as it is!
    davidtaylforth
    Wow! Very nice, I like all of the white parts, you just need some white Oakleys now and you’ll look absolutely great.
    Make sure you clean the white parts regularly, otherwise your bike will look loads worse than it does now.
    trickride
    140mm floats. Thought about the talas but after a test ride on some I took the plunge on the floats.
    Came in at 28.1lbs! Wheel set is quite beefy as is chainset so can see why.
    Yeah white bits are going to take some maintenance.
    Kryton57
    Going in on trend, thats either 27.5lb or 29lb. now way it’ll be 26lb, its not retro enough.
The topic ‘New BFe build’ is closed to new replies.
