Viewing 5 posts - 1 through 5 (of 5 total)
  • Netbook & Windows CE Dongle issue
  • Mounty_73
    My niece has a netbook with windows CE installed.
    She has a E170 T mobile usb dongle, when its inserted it asks for the driver, does anyoneknow if this dongles are supported by windows CE ?
    Stoner
    pretty unlikely.
    The Windows CE units arent sold as being dongle ready.
    Her best bet would be to get an unlocked/Three MiFI dongle and use that with the built in wifi card that the CE netbooks usually have.
    I use one with a WiFi only Android pad and it works very well indeed. Also means I can just hand it to Mrs S if she needs something when on the road with her laptop. Or even if we both need to share a connection when out in the camper van
    Mounty_73
    I did read somewhere the the Window CE’s were not compatible with dongles.
    Mounty_73
    Admirable – that looks good, would I be right in thinking that you would simply connect the USB dongle into that above device, then the Windows CE netbook would connect to the above wireless device, correct ? 😉
The topic ‘Netbook & Windows CE Dongle issue’ is closed to new replies.
