Nope.
Chrome OS is effectively the Chrome browser and a logon/file system.
When you turn the machine on you get a logon window, after that you get a desktop and taskbar. The only “Program” ie fixed-function application on the machine is Google Chrome, the browser. All other applications are actually webpages that run in a tab or window. For example pixlr – this is a photo editing webpage that behaves like a small photo editing program. The only difference with these web apps vs traditional apps is that they appear in a tab or window. [try pixlr for 5 minutes, you’ll see what I’m getting at].
There is a file system browser, you can navigate to a memory stick or external hdd much as you would on Windows/OSX/etc.
If you truly want a machine for web-use it’s going to do you fine, if you want something else it’s variable – you can for example edit Office documents using Google Docs, but that’s not where the strengths of the machine lie – you need to be online for that, and it’s just not quite as fast and efficient as having a copy of Word running locally on your machine and saving it’s own native files back to it’s own hard disc.
Another big advantage is security – Chrome OS is built to be very secure, it’s modern software so no old bugs, it employs several layers of anti-hacker technology and every time the machine is switched on it checks to see if any of the operating system has been changed in any way from what it should, be and if there’s any changes it just reverts to fresh install of the OS [which takes about 20 seconds].
That’s it in a nutshell, and don’t worry about using Chrome as a browser. With browsers [as with so many things] all the best innovations/features are copied by all the other vendors. IE/Firefox/Chrome/Opera all work pretty much the same and the switch will take you 5 minutes plus looking a little thing up every now and then. It’s not like a Minority Report Interface or anything 😉
EDIT – Surface RT, dunno man, dunno. Not tried one, might be nice, but I surely do hear about that platform being on life-support….. Even if Microsoft continue to expand their ARM software, I’d personally expect them to make radical changes to it that cut the support from the early generation machines. That’s just my guess.
I am also quite curious as to what Google are going to do to merge ChromeOS and Android. I am convinced they will do, but I just don’t know how.
