Personally I’d opt for the Quarries loop instead but if you go right at the end of Danebower, then take the first proper driveway on the left and as it sweeps round to the house, go right through 2, maybe 3 gates quite close together, you then pick up tractor tracks going left down to another gate, Left through this and kinda cut across the field, you’ll end up in a soggy sunken track with a wall running alongside on the left, follow this to the gate, straight ahead down a nice bit and when you get to the bridge on your left (3 Shires) keep straight ahead again, follow the climb to the top (Cut Thorn) , go right to the A54 and right again, look out for Cumberland Clough on your left.
The field will be a bit soggy but better to descend than climb it IMO
HTH
Carlos
