So first truly filthy ride yesterday since I went 1×11 on my Rocket.
Back end worked fine, however the ring (Hope Retainer) was making the most godawful racket when in the bottom 2 or 3 gears, which I guess is the poor chainline in combination with the close tolerance design of the ring. Post cleaning, it’s pretty obvious that I’ve taken a fair bit of metal off the outside face of the wide teeth.
It occurs to me, however, that I can offset the BB & chainset 2.5mm towards the NDS by taking the spacer out from behind the RH BB cup and sticking it on the other side. Anybody else tried this? I’m guessing it won’t make an enormous difference, but it might make some…?
