Teej, that’s called moving the goal posts, you said
it won’t unless its also more rigid / less likely to swell.
and I showed you that actually it will swell less. So are you now saying that it doesn’t make any difference if the hose swells? What about if it expands more than the lever travel?
It swells less so that for the same lever travel you will get more piston travel. This will alter the feel and performance of the brake in a like for like for like comparison. Whether it alters it for the better or worse is purely subjective, but it is a fact that the hose will swell less. It appears that users like this, hence braided hoses etc.
