Current bike is 22-32 double with 11-34 cassette.
New bike will be XT 1×11 when it is available. But until then I need a make-do situation.
The options are either:
– retain the current double set up (but I will need to buy a new direct mount front derailleur that I won’t need in the long run); or
– go 1×9
I think therefore I will go 1×9. I already have the 11-34 cassette so that is a fix but what chainring would people recommend 30T or 32T which end is it most annoying to be lacking at? I live in S. Wales and ride locally mainly.
According to Sheldon my existing double arrangement gives ratios of 1.3 to 5.9, a 30T would give 1.8-5.5 and a 32T would give 1.9-5.9. It seems that I am losing more at the bottom end so should probably go for the 30T.
Also which one should I get, cheap and functional favoured so I am thinking Superstar but it has odd looking threaded spacer tabs at the mountings, I am guessing this is to adjust the chainline and replace the chainring bolts? Any alternative recommendations appreciated.
