Talking of steerers, the threadless steerers I’ve seen all look a bit on the thin side for threading, even the steel ones.
There’s a quick and easy way to make a fork.
Get an old suspension fork with clamp on legs. These were either cheap BSO jobs or early mtb suspension. Most have a threaded steerer. That gets your fork crown and steerer sorted in one hit. It also lets you use 100mm OLD hubs.
Then for fork legs, find an old segmented fork with round legs (eg an Inbred) and cut the legs off.
The diameter of the fork legs is very close to the diameter that fits the above fork crown. Clamp them in and you’re good to go.
The offset may be wrong, but that can be fiddled with by reversing the fork crown.
Trail can be altered by working out what length of fork leg to use. If you leave a bit extra in you can adjust up and down until it feels right, then cut to suit.
I think have an old fork crown and steerer if you want to try it.
Alternatively, you can use a later type fork which has bonded stanchions. Then cut down a set of sliders to suit. It would be heavy for a wee folder.
I did that here to make an adjustable rigid fork experiment with trail and head angle for fatbikes.
I used seatclamps to clamp the legs, and had an internal spacer so it couldn’t collapse on to the tyre. click on this link to see the process.
trail_rat – Member
Because cannondale threaded alloy steerers were 1 1/4″ OD with relevent headsets to suit
Yes that’s right. STD 1 1/4 stems tho no?
Brian you’re basically admitting your sandpaper idea is time consuming even for polishing, and you want to use it for material removal?
I see your idea, but if you mean by “segmented” forks modern CSU style ones the the “stanchion” part is way larger diameter than what you’d find on old cheap suss forks (28.6mm etc like Judy’s have a price premium I think, I guess there are RSTs).
In the early days of threadless, even the late 90s, steel steerer were the same guage for threaded.
