- This topic has 78 replies, 33 voices, and was last updated 7 years ago by aphex_2k.
My Ford Focus engine is dead, options?
thisisnotaspoonFree Member
In fact there is one on eBay right now
Ebay item : 112141630841
In fact there are loads of them, I guess because kids love wrapping Fiesta ST’s arround lampposts.
ScottCheggFree MemberThe trouble with main dealers is that they won’t take shortcuts.
You need a new engine? Then it’ll be a Ford box motor. It’s not warranty so it’s likely Ford will, at best, make a contribution. This will still leave you with a very large bill; several £1000’s.
Tell the dealer to put it back to the condidtion it was in when you brought it in.
If it runs, WBAC it.
If it doesn’t; hire an engine hoist and buy a socket set.
rocketmanFree MemberThe trouble with main dealers is that they won’t take shortcuts.
This is the bottom line. My Focus had a terminal engine problem (blocked oilways) and they wanted £3.5k to fix it (2010)
Request that they put it back together and take it to an independent with the Ford dealer’s report and take it from there
zaneladFree MemberTemperature gauge – my Mrs genuinely didn’t know which one it was and when I pointed it out to her she had no recollection of ever having seen it before…..she’s been driving for twenty years and had that particular car for two of them!!
My wife’s the same with the fuel guage…… 😀
maccruiskeenFull Memberthen I’d learn to keep an eye on my temperature gauge.
They’re going out of fashion. My merc doesn’t have one.
That said if you’re losing/ lost coolant the temp needle drops – because the sensor isn’t in the coolant its monitoring anymore – rather than show you’re overheating. On diesels where the engine takes quite some time to come up to temp (my one with a temp gauge the needle doesn’t come off zero for the first 10 – 15 miles) you can be a long way into a drive before it can become apparent the gauge isn’t reacting.
bigdaddyFull MemberThe car does have a temp gauge, I know what it is and where it is – it didn’t respond to the coolant loss until the engine went into limp mode the first time. The second time, after the new hose, it was the temp gauge that alerted me – it was moving constantly between normal mid range and spiking up then coming straight down again, I guess because there was no fluid to measure.
I went and spoke to the garage this morning, apparently cylinder 2 is warped beyond the range for skimming it. The engine is in bits and I would incur more cost (beyond the £570 labour to dismantle and problem solve) to have them rebuild it. They said that if I could source a recon engine they’d fit it too which surprised me, but not going to let them do that. It does seem that these rogue coolant pipes are a known issue, but I don’t see that I’ll get anywhere pursuing that with Ford on a 5 year old car. Which leaves me I think with getting it to an independent for a second opinion and potentially them doing a recon, then selling it on. It’s a pain in the arse!
joebristolFull MemberMain dealer prices are normally outrageous. The local mini dealer quoted some silly high prices for work on my wife’s mini – took it to an independent mini specialist who sorted it for a lot cheaper. One of the main dealer problems identified wasn’t even there when the specialist looked for it.
I’d looK for a low mileage engine out of a written off car to go in the focus. Maybe find out how much the main dealer would charge for fitting and compare that to a couple of good local independants. Once done there should be no need to get rid of the car quickly – as long as the new engine is decent.
philjuniorFree MemberOnce done there should be no need to get rid of the car quickly – as long as the new engine is decent.
Also, “Loads of work done, engine just replaced” doesn’t look good on an advert.
XyleneFree MemberAre UK focus and Fiestas not getting huge issues with the powershift gearboxes?
RockhopperFree MemberOnly the petrol ones due to a failing oil seal. Diesels are okay.
singletrackandiFull MemberWow another blown Focus. I bought a 1.0l Ecoboost a few months back and the headgasket went. No independent garage would touch it and Ford told me it would be 2K for the head gasket alone and the price was likely to increase when they opened it up and started to look around.
Luckily for me Ford took it in PX and I’m now in a Diesel C Max.
retro83Free MemberThat engine is completely different to the OPs.
Guessing your car hadn’t been in for the recall and had the coolant pipe changed? It was a known fault in early cars. The pipe goes brittle and eventually cracks causing it to dump its coolant and overheat = blown head gasket.
singletrackandiFull Membersingletrackandi » Wow another blown Focus. I bought a 1.0l Ecoboost a few months back and the headgasket went. No independent garage would touch it and Ford told me it would be 2K for the head gasket alone and the price was likely to increase when they opened it up and started to look around.
That engine is completely different to the OPs.Guessing your car hadn’t been in for the recall and had the coolant pipe changed? It was a known fault in early cars. The pipe goes brittle and eventually cracks causing it to dump its coolant and overheat = blown head gasket.
Coolant pipes had all been done on mine, all nice new ones. (read up on this problem, but didn’t see that Ford had had a recall) I can only guess it had been boiled before I owned it and I was just unlucky.
TheLittlestHoboFree MemberHere is another suggestion. The ford dealer has done nothing wrong other than to diagnose the failure and suggest what others have already suggested they would do if in the same position. Expensive but unfortunately the case
Rather than use words like stealer etc, how about you call an independant garage of good repute and ask them how much they would charge to fit a second hand engine that you supply. Then call the ford main delaership who offered to do the same job and has your car sat there in pieces so will probably be in a better position already to finish the job. If they will match price then it just leaves locating an engine.
At the ery least it will give you some brownie points when you go to fordcustomer services and unleash hell on them about know faults etc.
Thats what i would do anyhow
horaFree MemberThelittlehobo if the car has full Fors history I’d lean heavily on the dealer and Ford customer services. Who serviced the car last and when?
Ford KNOW about the hose, dealers know about the hose. It should be the first thing checked at every main dealer service for condition etc.
I’d kick up merry hell.
However if you don’t support your LFD with your services you can’t do ^^
trail_ratFree MemberKlunk dropping In a different engine isn’t as easy these days-ecus and immobilisers plus insurance goes nuts.
Tbh insurance ime even get funny about non matching numbers even on same engine.
bigdaddyFull MemberThe dealer (it wasn’t me who called them stealers!) have been good about it. The only thing I’d say is that they serviced it 2 days before the first hose ruptured so I may have some comeback there… They have services the car since new, so I have supported the local dealer.
I am beginning to wonder if it’s worth the hassle of getting a new engine fitted, or whether to take whatever I can get for it without engine?
muckyteeFree Member2011 model… surely the ecu would cut the engine if it overheated before any damage was done.
I work as a bus mechanic all too often buses overheat and drivers run them until they cut out, these buses are were made in 2007, we don’t fit new engines every week.
Why exactly is the engine **** as you say, does it run? No misfires, smoke, low on power?
If it just overheats and there are no leaks, it could be the cylinder head gasket (coolant system pressure test will help you determine the problem) which shouldn’t warrant a new engine just a new gasket, should be able to get a good price for the job from an indy garage, common car so should be able to to find a lot of garages willing to take up the work.
RockhopperFree Member£1000 for a dead Focus with no engine… I can’t believe its worth £2.5k. I’d love to be proved wrong but the buyer very much has the upper hand in situations like that. Second hand engine £300 plus £300 for someone to bolt it in for you – job done. Its not rocket science (as long as you keep original ECU etc etc) and no need to inform insurance as long as its the same capacity engine..
muckyteeFree MemberTrail – rat
I appreciate that but I’d be very surprised that a modern car would allow the engine to get so hot that it would effectively destroy itself, I may be wrong. I’d just expect the maximum coolant temperature/engine shut down point to be lower with an ali head…
KlunkFree MemberKlunk dropping In a different engine isn’t as easy these days-ecus and immobilisers plus insurance goes nuts.
I wasn’t suggesting a different engine I don’t know what engine code the OP has it was meant as a guide to what he would expect to pay to replace the broken part (it just happen to be towards the top of the search and had a similar mileage).
bigdaddyFull MemberThe head is warped beyond where it can be skimmed, that’s why it’s dead. It drive – the tech I spoke to said he was really surprised that it was running, but running it was. Outside the parameters for fixing though. I guess because it lost all its coolant it couldn’t monitor temperature properly and that’s why it cooked…
horaFree MemberOP on one line of a post you wrote: “they serviced it 2 days before the first hose ruptured so I may have some comeback there… They have services the car since new, so I have supported the local dealer.”
Followed by your thinking which engine to buy.
Sorry, I’ll say this again- they KNOW, both dealers and Ford themselves about the weakness of the hoses on the eco boost engines. There MUST be a workshop bulletin that includes checking this/these at every service. To help your case further they saw and serviced the car TWO days before it failed. So you’d think they inspected the engine using their expertise and knowledge that you pay a premium for by choosing a main dealer network. This line can be giggled at but if you talked strongly to both the dealer and H.O using this/these angles I’m sure you’d get a good degree of goodwill. After all you are a loyal customer and their experts should be checking at every service for the known weak points.
Theres a legal expert over on Pistonheads Speed and law section who may be able to help you. However rather than spank 000’s on a engine- why not take be firm with the dealer principle/Ford customer services and then take legal advise.
I managed to get 2k knocked off a bill on a 7yr old Bmw mini a few years ago by talking to BMW- abit of research and showing them the known faults (politely but I didnt give up).
Good luck.
bigdaddyFull MemberThanks hora, what you say makes sense! I find myself veering all over the place with what to do, partly by a wife who doesn’t want the hassle!!
trail_ratFree Memberand no need to inform insurance as long as its the same capacity engine..
That is wrong . You need to tell insurance and you also need to change the engine number on the v5. I went through this last year changing my landies engine and previously doing an engine and gearbox swap on a mates punto. 1.2 out -1.2 in. Insurance went up 60 quid. Assuming it’s an engine out of another car with a different engine number to the stock. If you buy a new one from ford it will be stamped up with your existing engine number
When coolant leaves engine suddenly te coolant temp gauge goes down first. By the time the temp gauge reads too hot . Your engines burst.
Wife did the same to a golf we had.
muckyteeFree Memberbigdaddy –
If it dropped it’s coolant, why didn’t the low coolant warning go off, unless it didn’t work…. after it was just serviced?
bigdaddyFull MemberNo idea, but haven’t seen a low coolant warning at any point!
RockhopperFree MemberIts not a modification – its a repair – do you tell the insurance if you fit a new exhaust? No. Did your insurance company ask for the engine number when you took out the insurance? No, so why tell them if you change the engine?
trail_ratFree MemberNot all cars have them.
I had it on a Hyundai once – glad of it as it needed topping up regular) but 3 fords(all mid 90s mind) a Vauxhall a golf a land rover and two Peugeot’s haven’t had one. Just a coolant temp sensor.
integerspinFree MemberYour best bet is to find someone who can be bothered to fix it.
If I was going to replace the motor I would get one from billy’s, Bridges at Pease
Pottage, or a bloke I bought a lot of ford parts from was up one of the roads on
the right as you headed to Chelsea bridge, I can’t be any more specific.spooky_b329Full MemberHaving seen the comments about it being serviced just before, heavily weights the situation in your favour.
Ask the garage to contact head office to see what help they will offer…if its not very impressive or the dealer is slow off the mark, call them directly with the facts, (not a rant) just a customer looking for goodwill. At best you may get a discount, at worst you should at least be able to wangle warranty rate labour from the garage (perhaps including the work done). And perhaps they will still accept a secondhand engine, although they won’t entertain any comeback with subsequent issues.
I went to Honda directly about my Civic after the guy dealing with it sodded off on holiday, it has a known weakness with the clutch (not admitted by Honda, whereas your coolant pipe was a recall so they’ve admitted a weakness). Second owner, something like 80,000 miles and well out of warranty. I got a free diagnosis, free clutch and paid 2hrs warranty labour rate, they covered the rest. FSH seems to have been a condition of the ‘goodwill’.
robfuryFree MemberGet in touch with ford uk especially after being serviced by them 2 days before! Fully main dealer history will help too.
What was done at the recent service? Coolant change? Cambelt? Big coincidence hose goes 2 days after service. Possible but could be another cause.
Also if they first diagnosed it as the hoses then said it was fixed and handed it back to you. Is so wrong. They should of at least took cylinder pressures and checked coolant system after.
I think you d have a good case for at least a big lump off that bill at least.
trail_ratFree MemberI must admit. It does strike me as airlock…..
Do check see if coolant was changed.
We all make mistakes although Wouldnt be the first main dealer or Indy garage to have the apprentice doing the servicing.
robfuryFree MemberI agree with trail rat. Something doesn’t sound right to me. Garage trying to dodge a bullet especially if they changed coolant. Even if not and they didn’t pressure check cylinders. I d fight it.
bigdaddyFull MemberA bit of an update for you guys who offered such helpful advice and knowledge. We’ve been very fortunate and been given some inheritance money early to buy a new car, so are able to separate having a working car from fixing and sorting the focus. Such a relief! So new car sorted, and an email (with the dealer’s blessing) to ford, suggesting they replace the engine as a compensatory gesture. Well see where that goes! Thanks to all those who helped, this place is great for that stuff…
dooosukFree MemberHow did you get on Bigdaddy?
Literally a couple of days after you posted this, my mother in laws 12 or 62 plate Focus has had the same issue. Coolant hose gone, no warning of overheating etc.
She took it to her local garage who replaced the hose and then told her the engine was stuffed. It was trailered to the main dealer in Barnsley and to be fair to them they’ve been great. Have said they’ll cover all costs despite it being out of warranty and the last service or two not being with them. She even lucked out and has managed to get a courtesy car from them.
Hope yours turned out as easy.
aphex_2kFree MemberHow long have you had it? Was it new? Is there new car warranty left on it?
The topic ‘My Ford Focus engine is dead, options?’ is closed to new replies.
