my de razor shaving...
[Closed] my de razor shaving problem - help!!!
[#3696571]
just how the heck do you stop your mirror from steaming up?
its a nightmare, i spend more time wiping the thing down than i do shaving, and even they i have to peer through the rapidly misting up glass!
Posted : 20/02/2012 3:30 pm
wash it with shaving soap and rinse
 IA
Get the mirrror hot, i use hot water holding the mirror close to the shower, and turn up the shower for a bit. If the mirror's hotter than the air water won't condense on it.
Posted : 20/02/2012 3:35 pm
shaving soap trick works for me
Posted : 20/02/2012 4:58 pm
Open the window.
Posted : 20/02/2012 6:04 pm
Your obviously using the wrong razor and probably the wrong blades.....try and old tech and some shark blades 😉
Posted : 20/02/2012 6:14 pm
While on the subject, where do people start when they shave? I usually start upper right cheek by my ear, but went a bit crazy today and did my upper lip first.
The wild life I lead.
Posted : 20/02/2012 6:17 pm
I always soap my moustache area last, and shave it first. Bad habits are so hard to break.
Posted : 20/02/2012 6:26 pm
Right cheek first, then tache area, then left cheek.
For some reason, I always do under the chin last. Always.
Posted : 20/02/2012 6:28 pm
I wet my beard and lather up with hot water, but then switch to ice cold for shaving/rinsing.
Seems to give me a much better shave with less irritation (also stops the mirror steaming up)
Posted : 20/02/2012 6:33 pm
Heated mirror pad
http://www.demista.co.uk/Products/Demista-Heated-Mirror-Pads.aspx
It sticks on the the rear of your existing mirror. I have mine wired through the bathroom light switch so it comes on when the light is on. I have a secondary pull switch on the mirror so that I can turn off the heater in the summer.
Posted : 20/02/2012 6:41 pm
that makes sense, i do that with sunglasses and goggles to stop them misting.
Posted : 20/02/2012 9:25 pm
I very rarely have problems with the mirror steaming up, but if it does then I open the window and wait a little bit.
As for CaptJon's question about where do people start, I always start with my left cheek.
Posted : 20/02/2012 10:44 pm
I shave in the shower so never use a mirror.
Posted : 21/02/2012 9:06 am
I only shave in the shower and always use a mirror 😉
I have one that sticks to the shower glass. Works a treat.
Posted : 21/02/2012 9:13 am
Open the window.
My bathroom doesn't have a window, has a fairly decent extractor fan before anyone mentions that 'tip' 😉
Posted : 21/02/2012 9:20 am
