thanks to all the help and guidance from members of STWF I have just finished my first ever build. It was a very steep learning curve (before, I had never even removed a crankset), but the results look pretty good to me.
the spec is as follows:-
Cannondale Caad 5 frame
Marzocchi MX Comp oil forks
Deore XT hubs with Mavic 717 Disc rims
Continental Speed King 2.3 tyres
Easton EA50 stem (110mm)
FSA Carbon Pro O/S riser bars
Superstar lock-on grips
FSA Carbon seatpost
Charge Spoon (cro-mo) saddle in brown
Avid Juicy 5 hydraulics with Clarks sintered pads
Alligator 160mm gold rotors
Deore XTR rear mech (slightly worse for wear… to be replaced) with kcnc gold jockey wheels
Sram 11-34 cassette with Sram 9-speed chain
Blackspire FR 170mm crankset with Blackspire 34t Mono Veloce chainring
Shimano BB ES51 E-type bottom bracket
Gold anodised self-extracting crank bolts, chainring bolts and stem top-cap
Superstar XCR upper chain device
Shimano M540 SPDS
All up build cost is circa £540 and I have the original wheels still to sell.
Looks sweet. I had a CAAD5 frame for a while with a Lefty DLR on it. Was really quick bike. Shame my significant bulk cracked the chain stay and Crack-n-fail wanted a fortune for a replacement (I wasn’t the original owner so couldn’t get a freeby)
i’ve read the reviews on the caad5 frame and know that they built it too light… there are no cracks so far and i only ride leisurely cross country, so i’ll see how i get on… if the frame breaks, i will simply buy another hardtail frame and swap the bits over (thinking on-one whippet)
i’m quite chuffed with the cranket which looks the nuts… i think i must have found the last 5-bolt blackspire mono veloce chainring in the uk to go with the cranks i already had laying about.
for my next adventure, i’ve just stripped down my on-one inbred… not sure whether to go ss or not (it’s a geared version with discs and tora 318’s)…. hmmmm
Posted 13 years ago
Viewing 13 posts - 1 through 13 (of 13 total)
The topic ‘my 1×9 Caad5 build is complete – pics inside’ is closed to new replies.
