Can anyone confirm that an '04 MX Comp ETA is air sprung in the right (non ETA) leg? The marz tech blurb seems to imply so, but the manual doesn't say, just telling you that air preload should be set 0-15psi, and if air spring should be set 30psi+ depending on weight.
I would just crack them open and look, but my dad has my socket set at the mo 🙄
I adjusted preload until sag seemed right for my gf, but when I checked with a gauge it was down to 4 psi, and they feel very soft for me (even considering I am fair bit heavier than her), which makes me think they are air sprung, and so need more like 35psi in them.
Just don't want to over pressurise them if they're not air sprung!!
