I’ll give it a listen later when I do the washing up!
I used to do quite a bit, but was terrible at finishing tunes. I also did quite a bit of sound design (presets for soft synths and effects) and worked for one of the leading vst developers for a while.
I always liked messing around with other peoples samples and mixed down bits of audio, makes you step outside your usual noise.
I have a dump of various bits of mixed down audio, mostly as a back up for myself really, the last tune I did is right at the bottom and there is a lot of nonsense in there but here it is, probably best to work up from the bottom if you do listen, everything from ambient to weird noise to drum n bass, all unfinished…
I really must get back into it
