The machined profile makes a difference- some basically have a little shelf for mud to gather on, and if that combines with tight clearances, the wrong sort of mud (or mud/lube mix) can mean the chain sits on the mud and rides up off the teeth. It’s a design fault of some early narrow/wides basically, when Superstar “designed” their chainring by ordering someone else’s and tracing it, they copied the flaw.
IME Works doesn’t do it because they have a bit more clearance, Absolute Black do it a little bit but only if things are really bad. Renthal has a little mud scoop designed to prevent this but imo it’s in the wrong place, it’s their bigger clearance and smoothed edge to the “narrow” machining that fixes it.
I daresay you could relieve that section of the ring a little to fix it, never done that though, I just stuck with better chainrings.
