Are they any good? Using a neo guard which keeps most mud out of my face but stanchions get a coating and seals, and also the noise it makes on compression sounds awful
Is the MN any better?
Do they do a really really minimal sized one or are they all the same size? Want one as un-noticeable as possible
I really like Mucky Nuts – mostly due to how clean they keep your stantions.
If you want it “low key” then the black ones blend against the tyre pretty well. As they run fairly close to the tyre, and match its profile, they’re surprisingly “un-noticeable”
I really like ’em, way better than the neoguard imo for the reasons you say (also, it just looks better). I use the little ones year round, they come off for slop season as they do have their limits, haven’t used the bigger size.
(I go up to SKS Shockboards for proper horrible mud… bring forth the MUD CANOE!)
Cheers guys NW can you link me to a small one your using please bud? I want as small as possible version for maximum discreetness will all be black so as above sounds like it will blend into tyre / fork combo
I found them effective, but….
They deformed putting the bikes in and out of the car and wouldn’t straighten properly
At full travel, they bottomed out on the fork crown pushing the MN on to the tyre
They’ve been removed
I like ’em. Got em on all 3 bikes.
The real plus point is that they do protect the stanchions too.
The minor negatives are that they intrude on clearance (I’ve noticed this most when riding in sticky snow) and they can get bent out of shape easily when multiple bikes are stacked in the boot with their front wheels removed.
They’re good if there’s plenty of clearance in my experience; I switched to a Neoguard from a Mucky Nutz on one bike, as the Mucky Nutz kept catching on the front tyre. That was on a Fox fork with an admittedly pretty hefty Hans Dampf tyre. I transferred it over to another bike with a bit more front clearance and have had no issues with that one.
Mine kept breaking due to very very little tyre clearance so made my own from 1mm polycarbonate bought off ebay and zip tied it tight to the fork brace. It’s got a few scratches but is virtually indestructible even when bent completely in half with the front wheel off.
I made one out of the lid of a celebrations tub last winter for My DH bike, I’ll be doing the same for the HT this Christmas, might use a Quality Street Tub and do it in Purple…
Paying for a “fender bender” is almost as bad as paying for a “Neo guard”…
Mine was OK until a mud wedge developed between it and the tyre and within about 10 minutes it had been eroded so badly that the velco eyelets failed.
My fault for not clearing it straight away and for running a big tyre I guess, but as this was only the second ride with it on I was less than fluffed.
This. I snapped the eyelets on mine in a crash, so used it as a template for a polycarbonate one. I found 0.75mm sufficient though. Recently made a new one with the mounts in a different place to suit my double arch Magura’s
combine it with their ‘gut fender’ for ultimate protection. The gut fender is like a crud catcher, but weighs next to nowt and goes on and off in seconds with velcro. very very effective
Both those products were already in existence if in slightly Heath-Robinson diy versions. A lot of people don’t want to strap an old inner tube to their £600 forks or a cut up milk bottle to their brace.
Someone designed a permanent, adaptable solution, tested it, developed it, bought it to market….
It’s good to support things like that I reckon, though it’s pretty tempting to just essentially copy them I agree…
I have a Mucky Nutz, I broke the first one quite quickly and they sent me out a new one rapidly. Good people.
I have to say that in very thick, claggy mud, clearance becomes an issue. You want one of them hideous ‘THE’ motocross-type guards then.
Mind you, you can build yourself a diy version of them too.. 🙂
Got both on my Soul. Why? Because I have to justify to the wife why I paid £15 for a neo guard and I had the bender fender free with my Singletrack sub
It’s good to support things like that I reckon, though it’s pretty tempting to just essentially copy them I agree..
IIRC the neoguard patent was never actually upheld, due to the products lack of originality and a fair few preexisting “heath Robinson” examples being cited as “prior art”…
Similarly The bender fender is productionisation of an extant idea but ~£8 a go plus the pensive wait while RM decide if they fancy delivering it, you could have made several versions from various bits of reclaimed packaging. You tell me which is the best use of those opposable thumbs and that evolved simian toolmakers brain?
There seems to be a lot of waffle about “supporting” companies spouted on STW these days, and gushy praise when they comply with their responsibilities under SOGA in a timely fashion.
Its just a business, this one helps people who can’t operate scissors. Well done them…
Posted 10 years ago
Viewing 30 posts - 1 through 30 (of 30 total)
The topic ‘Mucky nutz fender bender’ is closed to new replies.
