So I’ve been looking at secondhand frames recently and I had the opportunity to sit on a couple bikes on saturday to try and see what size is good. I’m 5′ 10″ so reckoned I’d probably be a medium on most frames.
First bike I on was a large Commencal Meta SX (with 50mm stem), which was pretty much perfect. Commencal’s sizing has me being either at the top end of a medium or bottem end of the large. I like a chuckable frame and usually the smaller size is the way to go but anything smaller than that large would be cramped. (it has a top tube of 605mm)
Next was was a Specialized Stumpjumper. Once again, a large (again with 50mm stem) but strangely in comparison to the Meta SX it felt smaller/almost cramped in comparison.
When I got home I had a look at the measurements and that was even more confusing. The stumpy has a top tube of 616mm. So the stumpy should have felt longer rather than shorter.
Ofcourse to complicate things further when looking at Commencal Meta frames, I found a 2012 Meta AM large, (which I though was basically the same frame as an SX but with a different rocker link) however looking at the measurements for it, it has a 620mm top tube rather than 605mm of the Meta SX.
So is it basically impossible use top tube lengths to compare full suspension frames.
