thinking of getting these for my commute to work, a mix between on and off road, have the cheaper wire bead version of thbese and they seem ok but want a stronger sidewall for tubeless as the wire beads seem very porous.
I have 2.2 at the moment but they seem very skinny and prefer the look of the larger width. the 2.2 come in at 52 so slightly under what they are meant to be, does anyone know if the 2.4 come in smaller aswell?
my main worry is tyre clearance between tyre and chain stays. with a 2.2 I have around 10mm each side, I fitted a 2.4 racing ralph for reference and it leaves around 6mm each side, is that an issue or am I just being silly about it? my wheel is true but both tyres seem to have wobble so the clearance changes (larger slightly) as the wheel rotates, sure my dish is off by a few mm which I don’t help but cant see it being a huge issue? should I take it to lbs to get it sorted?
