I’ve not ridden in over 10 years now, but just off to pick up one of these…
Been an itch that’s needed scratching for a while now, and a recent change in circumstances has given me the push to get back on one. Found what looks like a good 99V plate VFR800 for relatively little money, sold my CX bike (which wasn’t being used anyway) to fund most of it, and got my old motorcycling gear out of storage (surprisingly all still in good nick aside from the gloves) and am off to pick it up this evening! Can’t wait.
It’ll be a total departure for me too, as only ever had arse up head down sports bikes before, and now I’m almost 37, I figured I should at least be a bit sensible (to start) this time round. Whilst I could have afforded to buy a K1 GSXR1000 and insure it, 160bhp when I’ve not ridden in over a decade might be a recipe for disaster!
Mine has been parked for a few years but still got it. I lived and breathed bikes for years but just fell out of love I guess and pushbikes filled the space
Poor thing doens’t look like this now after years in storage…
I’ve got a 2002 Bandit 600 that I’ve had from new but – like you – I’ve not ridden in over ten years.
Funnily enough, my itch is a VFR800 too, but the VTEC model with the high-level exhausts. They had just come out when I bought my Bandit but my budget did not stretch nearly far enough for one at the time.
Or just take it easy, the throttle works both ways. If you’ve ridden a pushbike on the road regularly in your 10 years off it’s just a case of applying the exact same skill set, ablit at higher speed*
I’d be more concerned about the 10 year old crash helmet to be honest, they’ve got about a 3 year lifespan after you’ve first sweated into them, even if it’s ok now I’d put money on the lining disintegrating in fairly short order.
*went back to riding on a cbt after 10+ years off, couldn’t work the clutch in the carpark bit, but impressed my instructor with my spidey-sense ‘that pillock hasn’t seen me’ emergency stop during the road bit. Instructor was surprised ‘bloody hell! you CAN ride a bike’
Over the last year I’ve taken an unhealthy interest in custom R80-100’s in the cafe racer styleee. I swear I’ll never get one, but damn if it’s an itch I should scratch.
I rode for a number of years, on some pretty focussed bits of kit previously. I’ll look into advanced training at some point but part of the reason for the VFR was to get something that wasn’t as focussed and though quick enough, wasn’t going to egg me on to chase the lads on their race reps.
I actually still have my Ducati 748SP in my Dad’s garage, it’s not run in 12 years probably. Needs a full overhaul, but given the fact it’s an appreciating classic now and my desire to keep it indefinitely, I’m in no rush to get that back on the road…
Seems ok, but will more than likely be the next new purchase…
Duke 390 here after a similar amount of time off bikes to yourself.
Plenty enough zip to have fun on the twistys and good position for in town riding too. Feet up U-turns are a doddle on it.
Had a test ride on an xsr700 though and that engine is peachy and the yellow speedblock does it for me having grew up watching the trans-am race series.
It’s more likely that my dad’s 79 400/4 will be my next though – if we can ever get it to run reliably and the front brake to be a lot more effective than it is.
Hi
2012 Triumph Speed Triple 1050R here.
Traded my Aprillia Tuono in for it last year.
It’s got all the Ohlins/Brembo/Arriw cans/carbon fibre bits you can shake a stick at and I love it!!!!
Shame I’m crap!
Steve
Sold my Fireblade 3 years ago to put towards a deposit on a house…in truth wasnt that upset to see it go, as it was so bloody good it made riding at speeds that dont result in a jail sentence seem very very dull, and my skillset was simply not upto riding fast at anything like a safe standard. I didnt miss riding at all until i saw the Triumph Bobber…..now i REALLY want of those.
If its anything like my 78 GL1000 ( which was my dads) then the front brake is just for show really. Mine has twin disks but they put a really weak master cylinder on it as they were worried people would lock up to easily!!! You can get an uprated one now. I only go slowly though!!
Ah the joy of 90’s Honda electrics! Bulletproof engines and electrics which may as well be Italian!
Give the charging system a good check over, lights on, 5000 rpm and you should get 13.5-15.5 volts. More or less then that and you have problem. Rec/regs have a habit of failing and taking the whole charging system with them so worth a check.
I think the problem with the running on the Honda is more to do with gummed and unbalanced carbs. I’ll check the electrics a look at though too as cleaning carbs is not a favoutite job – especially 4 little tiny ones
The front brake is a swinging caliper with only one active piston. Even when it had been stripped and a new pivot pin, fresh fluid, seals and piston it offered naff all retardation. The rear drum however could lock the rear with a tap of the toe!
I know I came to it all very late but the idea of old bikes with weak brakes etc just turns me off hugely. I just can’t imagine riding something without ABS, traction control etc. I don’t even have to use the clutch once moving on current bike…
You should feel what its like at over 90mph if you hit a slight ripple in the road ( well autobahn obviously!!). Poor brakes are the least of your worries then!!
Well my previous bikes were other 90’s Honda’s, and a 90’s Ducati. So I’m well prepared! 😆
It’s the same appeal as old cars. Far more involvement at much safer speeds is the idea I guess. Wouldn’t want something with drum brakes and crossply tyres as a daily ride, but probably good fun once in a while!
Also have a barn-find vfr800fi that i hated riding and killed my interest. Need to get round to advertising it but cba with the haggling and for 300 just want space in the garage. Decent stealth ad? 🙂
Much more fun wringing the neck of something with 100bhp than bimbling about something with 150+.
V4’s are the sweetest sounding engine. Had the last of the 750’s and it was a joy to ride. Utterly reliable (probably the most over engineered engine in a proddy bike) and comfy for just riding about but could hustled along rightly. Suspension is a little soft for hard road/track riding but great fun. Fit a race can and listen to the angels sing 😀
Heres a few pics of current bike and some of my previous bikes. BMW F800GS is what I’m riding now after many years of sportsbikes and some trailie bikes.
Loved my GSXR750s. Had 4 of them carb’d to 1st fuel inj SRAD, to K4 + K8. Lots of trackdays and many trips to Nurburg+Spa. I do miss the acceleration and damn outright power of a sportsbike!
I ride to work everyday, whatever the weather – just love being on 2 wheels 🙂
Moto Guzzi Centauro here, owned for 11yrs but not ridden for the last two after taking it to RAF Benson and realising how much tinkering it needs to get it running sweet again 🙁 hopefully this year will see it back on the road
Nice to see a couple of others with ‘Guzzies. I have a Breva 750ie. It’s the most forgiving bike to ride ever and the exhaust with tweaked baffles sounds so so good.
