No charger, but I do have a multimeter, so I should be able to check the battery in its current state.
OK, you might know all this already so forgive me if you do.
First, check the voltage with the ignition off, you want to see about 12V
Then, check the voltage with the ignition on and the headlights on, see if it drops much. I don’t know how hard your bike draws, but I’d expect to see it no lower than 11V. If it drops lower then generally the battery is either not charged, or buggered.
Then, start it and hopefully see over 13V (apparently, for most trumpets- this varies a bit, my suzuk/honda mashup charging circuit showed 14)
