What do I win?
Bike Forum
Most ridiculously overpriced piece of bike bit
Posted 4 months ago #
Expensive pedals!! They get stamped on knocked by rocks, get covered in crap!!
Posted 4 months ago # -
Assos clothing - I hate the brand / its advertising / its crap pretenious nature and dubious longevity
Chain oil / sus fork oil = I just buy from motor factors
Brake pads /tyres and new sus forks = stupid prices
I buy 2nd / 3rd hand or get friends to buy from abroad on close out = I cannot remember the last time I got something brand new from a local UK LBS - I used to work full time in the trade - kinda made me question why the industry sells stuff way way above what it is ' worth ' and how we all fall for it - odd snobbery value in showing you paid loads...
Plus expensive stuff isnt always the best - look at me - I got some silly expensive frames at trade prices and some broke or some were just underwhelming - as I get older I see less 'value' in expensive kit and I would rather spend it on trips away actually riding my bike... I am a deore vs xt/r rider now !
hey ho
paul
Skywalker, nothing, I already called it....
Win.
Replacement dropout for my Lynskey. £50! B@st@rds.
I don't know why people buy XT or XTR derailleurs, they get smashed on rocks and covered in mud/grass/twig...
That garmin cable is just downright dishonest.
and how can the Intense drop outs cost as much as a whole on one frame?
I thought (I still do) the new swap out drop outs from On One were expensive.
Win.
That doesn't count, some idiot asking way too much for a second hand frame!
Any top end bicycle. £8500 for a Scot Spark and you still have to pedal
After all these replies I can't believe nobody has mentioned 9 quid for a small sheet of thin plastic and a little roll of velcro to strap to your fork bridge.Suppose i'd be too embarrassed to bring it up if i'd been mug enough to buy one.
How? What's to wreck? Maybe you need a torque wrench so you install it properly
How? Dunno. I always have got through headsets (and rear wheels/hubs) rather quickly, ever since the days of threaded steerers. Any cheap headset will do well if it lasts above a year for me on an MTB. Only King ones have ever been any good for me. I did get a Cane Creek 110 for £29 a while back but it's on a bike that hardly gets used.
And where exactly do you use a torque wrench on a headset pray tell? It's all done by feel is it not? Just nip it down to JUST remove the play. I'm the best mechanic I know, FWIW, as at least 3 people on STW will confirm
I only buy my King headsets used though. I'm no mug
EDIT
Just remembered I have an On One headset on my C456 which is about 15 months old and still OK, but that's an internal top race and a 1.5 bottom, which might help.Posted 4 months ago # -
Yeti Big Top Single Speed drop outs...........£120 !
Yup, £120 for 2 bolt on pieces of alu. Now thats a con for sure !Needless to say, I didnt !
I think dropouts appear to be winning for me, >£100 per side!
£180 Avid brake body replacement presumably includes labour or does the body really cost more than the full brake?
The joystick mount I reckon is reasonable, lasts a while and bloody useful. the zipties and plastic block might be a little pricey but £10 isn't silly money.
Shimano's replacements always seem a bit daft, 3 rings cost more than a crankset, jockey wheels, freehubs, etc But is that stupidly priced replacements or very competitive original units?
What is it with forks? Six or seven years ago, £500 would get you a TALAS with all the bells on it. Now you're looking at nigh on double that.
£4,599 for 'VIRTUAL' pivot point full sus bike...dare not ask the price of one with a real pivot point
This:
http://www.chainreactioncycles.com/Models.aspx?ModelID=22487
It's like 4mm in diameter! Outrageous cost really on something you can lose very easily
the £80 labour on a fork service.
Finish Line DOT5.1 brake fluid at £14.99 for 240ml.
You can get a litre of the stuff in Halfords for £12.99.
Chain oil and 44t chainrings
Dura Ace outer chainring. £100
Any bike lubricant with the words "juice" or "butter" in it's name to disguise that fact that it shares it's origins with much cheaper stuff.
Take Finish Line Teflon Grease - remove the label...ah, White Lightning Pool and Spa Lubricant. So much for being "Formulated for the unique and demanding non-hydrodynamic requirements of a bicycle bearing".
PrinceJohn - Member
Today I was quoted by the bike shop for a new brake lever assembly, for my avid juicy ultimates after the bolt the mount had cracked...£180.00
just for this bit....
Same thing happened to mine - I think I have another lonely lever somewhere if you are interested...
The Garmin cable is outrageous
The Intense dropouts are astonishing, at that price you could actually buy a small milling machine and make your own for less.
(ok, obviously you'd actually just totally fail to make your own, and get swarf in your eyes to boot, but in theory you could)
coatesy - Member
Weeeeellll... This is where it gets less simple isn't it. Because sure, everything you say is correct but at the same time, I can't think of anything else I've bought for under a tenner for a bike that's been so brilliant. VFM is about cost vs benefit as well as cost vs production cost IMO.
The Garmin cable is a rip, but I believe that their devices are quite flaky when connected to the PC with a normal USB cable. I know mine struggles if it's not being treated as a USB hard drive on a normal cable. No excuse I know, but I believe that's what someone might buy that cable.
I agree with this it took 1/2 hour to service an old pair of Dukes if they have to get sent away for a service I may as well buy new ones
SRAM powerlink Evans £15.99
£3.99 for 3 at CRCPosted 4 months ago #
Reply
You must log in to post.
