Confusing to say the least (to me anyway)
Website says PdS lifts are open and to do the loop you typically would use (from Morzine)
SuperMorzine, Zore (Morzine into Linderets)
Chaux Fleurie (Linderets into Chatel)
then …
Mossettes (from Swiss side) to get back to Linderets
You can then ride down to Morzine via Linderets village without another lift though it’s a bit roadie/off piste and better/normal option uses Les Linderets lift
However the website lists some of those closed 😐
Also the link to the timetable points to 2015 😳
You can drive easily from Morzine up to Linderets but that’s no use if Chaux Fleurie is closed. Its a very long drive to Chatel.
Plenty of riding in Morzine/Les Gets inc enduro stuff off Mont Chery into Morzine and the Les Gets / Lac Joux Plan / Samoens ride (needs taxi/car uplift back). There was another thread on this recently. However a bit less convenient than full PdS system and you miss out on the excellent Chatel bike park plus enduro rides like Col du Coux unless you are prepared for major pedalling up.
