• This topic has 28 replies, 15 voices, and was last updated 7 years ago by Drac.
Viewing 29 posts - 1 through 29 (of 29 total)
  • More Maths help required…
  • vinnyeh
    Son (yr 4) has a homework ‘challenge’… I’m at a loss without going back to first principles i.e. cutting out the pieces, though some abstract thinking suggests there is no solution 😆 – otherwise the only thing I can think of is that the squares are used to form the perimeter of the rectangle, which will then be hollow..
    I have 9 squares with sides of length 1cm, 4cm, 7cm, 8cm, 9cm, 10cm, 14cm, 15cm and 18cm. They can be fitted together to form a rectangle. What is the width and length of this rectangle? How do you know?
    Is there something obvious I can’t think of?
    davidtaylforth
    Make the squares out of some pieces of paper and then fit them together
    davidtaylforth
    Work out the total area of the squares which will give you the area of the rectangle. Then work it out from that 😀
    Year 4 sounds really tough, glad I got it out the way when I had a brain that worked properly
    munkster
    That’s what I thought but (unless I’ve been silly) the total area of the squares is 1056, which isn’t a multiple of 18. Gut feel is that the rectangle surely has a width of 18, but obviously not if 18 x something has to equal 1056?
    Edit: of course I am assuming this rectangle has no “holes”, ie. all the rectangle is purely made of these squares. That isn’t specified is it?
    handyman153
    Same as Munkster –
    The total area doing that method would be 1056, and i can’t work out how to make that out of those shapes..
    It’s annoying me now, i’m sat with cut out squares on my desk!
    davidtaylforth
    22 x 48
    Wally
    Daughter on the case
    poly
    Well working out the total area (which you have done and is apparently 1056), then you can factorise it to find all the factors >= 18 (because as a minimum the 18 square needs to fit)…
    Presumably only one of these has values that can be obtained from the sum of the values available.
    That said, this seems rather sophisticated for what 9yr old maths…?
    TiRed
    https://goo.gl/images/ZMIUK0
    Sad when google replaces maths.
    davidtaylforth
    THat’s barely a rectangle TBH
    munkster
    vinnyeh
    starting with the smallest square, I don’t see how the 1×1 square can ever be integrated, unless the rectangle is partially hollow, but can’t prove it. Which would mean that the rectangle must be partially hollow.
    All instructions on the piece of paper have been given in the first post. It seems to be a ‘stretch’ task, but obviously no questions were asked in class when the work was handed out…
    That’s what I thought- originally I thought it was a piece of work given to his older sister.
    Wally
    Yay! but our 15×15 and 14×14 are labelled wrong. 22×23 rectangle.
    thecaptain
    Previous posters have pretty much nailed it. You need two factors that multiply to give the total area, and they both need to be at least 18. You should start by listing all the prime factors, e.g. 2x2x2x3x…whatever.
    I was pretty good at maths as a child, don’t think I was doing this sort of stuff aged 9 though…if that’s what year 4 means (no kids myself no idea).
    TiRed
    I think the idea is to get them to play with the physical squares. Or google “factor 1056 squares” and click images. Proving there are multiple solutions would be harder. Or no more solutions…
    The link is actually very good. Might be where their teacher lifts the problems 😉 . I’ve been revising C1 with Teen2 this evening. Love a bit of sequences and series. Setting problems is surprisingly hard.
    sc-xc
    Where’s your 1×1?
    thecaptain
    Someone did their sums wrong that’s 506 not 1056 which makes it rather easier as 23 is a prime factor so there’s no choice, it’s just a matter of finding whether the shapes fit.
    Onzadog
    In the middle of the 7,8,9 & 10
    munkster
    What’s 506 and not 1056?
    handyman153
    thecaptain – Member
    Its definitely 1056!
    Also Wally, isn’t that a 32×33 rectangle? And 32 x 33 is 1056?
    sc-xc
    Oh yeah! It’s small. Being 1×1 I should have expected that..
    thecaptain
    It was the guy who said 22×23 who did his sums wrong 🙂
    jam-bo
    Sure about that?
    18+15 =
    18+14 =
    Wally
    Whoops, I was rushing and had a clarinet one foot from my ear and continue to do so. I chose my forum name carefully..
    spxxky
    That should be 33 x 32 surely?
    TheFlyingOx
    Those cut outs don’t make a rectangle.
    Top? edge is 18+14 = 32
    Bottom edge is 15+10+9 = 34
    Left edge is 18+15 = 33
    Right edge is 14+8+9 = 31
    That’s a… quadrilateral?
    POSTED 4 MINUTES AGO # EDIT DELETE UNDELETE LOOKUP WARN BAN MESSAGE REPORT-POST
    Because
    bruneep
    Bit harsh we’re all guilty of skim reading.
    Ooooops! Copied too much. 😳
The topic ‘More Maths help required…’ is closed to new replies.
