The standard set up on the teocali is very poor as far as the linkage is concerned.
I have now killed 3 sets of bearings due to the total lack of a seal to keep the moisture out. Once i get a new set of bolts i will be having the bush conversion done as it is bound to last much longer.
I do have the e mail address for a guy from the forum who will replace the bearings with a bush. He charges £35. This is about the same as a link kit from Hotwheels ( UK distributor).
If anyone need to order a kit or any or the parts here are the Stock and Alternative codes –
Stock/Alt Code/Description
WS00/WS00/Link Body(x1)
MTBMG11/1210/Bearing(x4)
MTBMG14/B341/Hollow Axle (x2)
MTBMG15/B366/Plastic washer (x4)
MTBMG16/B367/Alloy end caps (x4)
MTBMG23/????/Bolt assembly (x2)
The bearings are type HK1210.
