Viewing 40 posts - 1 through 40 (of 72 total)
  • Monday Brain Teaser: Tim Peake's Astronaut Test
  • GrahamS
    (Source)
    I make it front right.
    Too old to be an astronaut anyway.
    Hang on – there’s 2 possible forwards (and backs) (but I think it still ends up in the same place so it don’t matter)
    Where’s the answer?
    GrahamS
    (it’s not a trick question)
    Fresh Goods Friday 696: The Middling Edition
    Fresh Goods Friday 696: The Middlin...
    Latest Singletrack Videos
    bikebouy
    Over there..
    mikewsmith
    Where it started.
    allfankledup
    as per mikewsmith – on base – the cube has rotated, but sits the way up it was initially
    thegreatape
    Back on the bottom.
    I don’t think it’s where it started, cos theres a ‘backwards’, which moves it to a side..
    mikewsmith
    Forward –
    Left –
    Left –
    Forward –
    Right –
    Backwards –
    Right –
    Edited – rotate your phone to see
    robgclarkson
    bottom
    Flaperon
    On the bottom.
    jimdubleyou
    It’s on the left hand face as you were looking at it originally.
    GrahamS
    The diagram shows the four possible directions the cube can move.
    It doesn’t show your point-of-view. You are positioned facing the cube and “forwards” is towards you.
    Where’s the answer?
    I know it. I’ll post it later.
    theotherjonv
    on the base.
    Or if you want to be tricky, you could ask with respect to what frame of reference has it moved, because in respect of the cube, it hasn’t at all, it’s where it always was.
    DrP
    facing right….
    DrP
    (edit – this was with ‘forwards’ with the cube rolling away from me..)
    (double edit – misread the first firwards…one sec…)
    (triple edit – back on the bottom)
    I’m sticking with my original answer!
    (Ha! Same as DrP. An he’s astronaut material 🙂 )
    taxi25
    Back to the bottom.
    mikewsmith
    DezB – Member
    grab the nearest box shaped object and test your hypothesis
    DrP
    He’s daft – Dez – grab the nearest cube with a dot on the bottom and test your hypothesis 😉
    DrP
    wukfit
    On the bottom
    During some of the moves it doesn’t actually move
    njee20
    Not on the bottom, surely?
    The lefts don’t change anything, but it ends up on the top after two ‘forwards’, then there’s a right, which puts it back on the bottom, then the ‘backward’ at which point it’s facing you, no?
    No. It says “minds eye”. 😛
    wukfit
    Njee the move right only puts it onto the right hand side, not the bottom, no?
    @GrahamS – You need to put the answer up before people start cheating and using their CAD software (or origami)!
    njee20
    Oh shit, yeah 😳 , i was doubling the roll to the right.
    I’ve run through again and think everyone’s wrong. It’s on the right.
    mikewsmith
    Well, I got the same answer doing it in my head as I did rotating my phone in my hands so I’ll stand by my answer.
    perchypanther
    It’s on the cube. Do I win five pounds?
    DrP
    Soo..anyone had the call from NASA yet??
    DrP
    donald
    Bottom
    Lester
    on the back face ? two forwards put it on the top, right or left keeps it in same place but dot rotating, then one times back puts it on back face ?
    sadexpunk
    Bottom.
    rmacattack
    the left do nothing, its on the bottom side of the cube,original position
    FuzzyWuzzy
    Bottom (the two lefts and the one backwards don’t change the dot’s position)
    mikewsmith
    A lot of confidence… who has done the experiment?
    km79
    Definitely bottom. Forward and forward puts it on top. The two left’s do nothing, right and right puts it back to bottom, backwards does nothing.
    GrahamS
    NASA ESA. 😉
    mikewsmith
    Space Australia are hiring.
    You realise your phone isn’t a cube? 😉
    How so? Oh, it looks like you’ve followed different instructions..
    mikewsmith
    True, it does have 6 sides and a dot on the back though.
    How so?
    Dot is on the side at that point
The topic ‘Monday Brain Teaser: Tim Peake's Astronaut Test’ is closed to new replies.
