Assuming you ignore all the common 😆 sense above think back 30 years to what the CXers did. Heels are easy. Screw, from the inside, something with tread on. We nailed bits of old CX tyre onto leather soles so adding a chunk of old MTB shoes is a piece of cake. you no longer have to worry about getting bulky toes into toe clips so some thing similar can be done at the front. DO it once, try to work out how much screw protrudes inside then remove the crew, cut it down and replace. Use a punch maybe to bend over the screw end instead and remember that the insole will sort out a few mm. To me its just a waste of a good shoe when the real thing would be better but its easy enough to do.
Having played with some S-Works road shoes this morning the small piece of tread at the heel is removable via screws from the inside, so you can definitely attach tread there. The forefoot would be the bigger issue, but the sole is quite flat, so I reckon you could glue it.
I actually use Egg Beaters, so Quattro cleats would fit, avoids issues with adapters:
May need to be trimmed so you could get some more aggressive tread up the outside.
Good thought, but I’m not going to start making holes in them, it would be glue or nothing, that way if it fails I’ll just use them as road shoes, without additional holes!
I N R A T S but I reckon some carbon fibre and a spoon would sort this out no problemo.
I wondered if it was more spork territory myself.
Bont?
They do custom shoes don’t they? Should be able to do pretty much exactly what you want I’d have thought?
Good thought, big money though, particularly when I get Spesh at trade.
That said, not sure it’s gonna be a goer – the Cvndsh road shoes aren’t on the dealer site, may be concept stores only. Haterz rejoice 🙁
Running Conti Gatorskins with the tread from a Surly Nate stuck on with Araldite at the mo.
Perfect for the slightly uneven gravel we get up here.
Look great on my Santa Cruz Oprah.
Good grip and ultra light weight.
Used the 25’s instead of the 23’s though.
23’s off road would just be stupid.
If they’re available then yes, I am buying them. I will play around, if it fails I will have some nice new road shoes, and I’m no worse off than when I started.
I think they may only be available to Concept Stores though.
he US gets white S-Works MTB, god knows why they only imported black and black/red.
Perhaps it’s because we (well, most of us anyway) have better taste. And that we hve stuff called mud here. As well as a whole raft of other very good reasojns.
I’m advancing footwear for the masses!
You’re not. You’re really not.
Maybe you’d like a pair of these?
In time, you’ll come to realise how lucky you were. 😉
Dunno, gonna screw the heel bits, unsure whether Shoe Goo or Araldite would be more effective.
You’re not one of them though, as you had to start a thread for advice on smart clothes because you’re a fan of “shorts and sandals”, and think C+A is a good place to buy a suit!
And yet my 3 year old ones still look very white because you can wipe them clean, anywho, you’re annoying and being useless, go away.
Oh come on; wanting a pair of the wrong shoes in the most impractical colour for mtbing, and publicly declaring it, yo’ve got to accept a bit of stick!
Why’s it impractical? They clean up perfectly. As you’ve never tried it I’m going to just leave your utterly useless opinion on the side here for you to collect when you leave! Good boy.
Njee20; I am very sorry that I may have upset you with my comments, they weren’t meant to be at all malicious or insulting. Iwasn’t ware that you might be quite sensitive about this. I apologise.
Well the LBS are going to try and get me some of the Cvndsh shoes. I’m not holding out much hope, and CBA to go to the hassle for the ‘normal’ S-works road shoes.
Just had a brainwave. Do you have any current MTB shoes? Why not take a mould of the tread and cast a whole new sole including tread. Copy the Cleat slots over, drill out and glue the new soles to the existing new sole with a decent 2 part glue like Araldite or Fusor / Würth Replast.
I had a pair of early Sidi MTB shoes in the early 90s. They were road shoes really, with a half arsed rubber sole attached.
The were super comfortable but had no protection around the toe box: I broke one big toe and frequently bruised others from hitting rocks over the years I had them. I’m older now, and dislike pain even more so I’d never wear a shoe off-road without a good, strong toe box.
Well the S-Works MTB shoes and road shoes have exactly the same toe box, so no more protection from the MTB ones.
Surely that would be less likely to stay put than glueing individual tread blocks on? As they’re available separately.
You have the 3 inserts for a road cleat that could be used to affix at the front and use the rear inserts for err the rear.
If it was me, I would stick some surf board foam on to the sole and carve out a new grippy sole pattern. Then use this “buck” to make a mould and cast a new sole in rubber. You can even mould in a support shank. The more I think of this the more I like your idea haha
Thanks for those who advised, I could get the Cvndsh shoes, but only by buying 6 pairs, whilst I’d use two, I’d struggle with the other 4, so back to the drawing board! Not sufficiently keen on the S-Works road shoe to try and bodge a conversion.
