Viewing 8 posts - 1 through 8 (of 8 total)
  • Modifying a bike rack for fat wheels
  • wurzelcube
    Anyone modified their Thule / Atera / Buzz tow bar mount bike carrier to take fat wheels?
    I’ve tried cutting a section of guttering but it seems to have too much flex when even when bolted down tight to hold the front wheel straight.
    boriselbrus
    Interesting – I bought a piece of square section guttering to try this exact modification tomorrow. I’ll let you know how it goes…
    garage-dweller
    Can you get some strip metal / bar from a motor factor and scratch build some wheel rack extensions?
    Or maybe make something out of some cls/ treated timber , thinking with some grooves cut in and shaped to fit round the existing metal work.
    singlespeedstu
    I just extended the length of the straps on my Atera.
    Works fine.
    Andy
    Yeah Thule roof rack here – just use longer straps – 2 toe straps or a Bungy per wheel. Has worked fine for last two years.
    boriselbrus
    I tried my modification this morning and it works fine.
    4 slots cut in each bit of guttering and jubilee clipped to the rack. Longer straps added and it’s rock solid. I do need to get some shorter jubilee clips and cut down the straps though, but frostbite was setting in at this point.
    [url=https://flic.kr/p/Dv5eRR]P1300001[/url]
    [url=https://flic.kr/p/CFPXas]P1300002[/url]
    [url=https://flic.kr/p/DsVRyo]P1300003[/url]
    [url=https://flic.kr/p/DcdNof]P1300004[/url]
    wurzelcube
    Thanks for the photos, got mine finished today – could have been that the guttering i was using is cheap so reinforced underneath and now seems pretty solid.
The topic ‘Modifying a bike rack for fat wheels’ is closed to new replies.
