I’ve used a Mobi Pressure Washer to clean my bike for the last 6 months. I’ve been told by a bike mechanic that these cause damage to the bike. However I thought the Mobi Washers were designed for this purpose, and that the pressure is too low to cause any damage.
On a £2000 full suspension bike I’ve had to replace the headset bearings, bottom bracket bearings and the front wheel bearings in just 6 months.
Is this normal to replace so much in just half a year or is it the Mobi that has caused the damage?
I make sure the pressure is not on full power whenever I’m cleaning anywhere other than the frame or tyres, and try to avoid spraying at the bottom bracket.
I’ve also been told by the said mechanic that the mobi can damage suspension and suspension pivots ?
