Iv set up my new Formula Rx front brake using a Shimano 180mm center lock rotor and shimano 180mm IS to post front brake adapter as these are bits I had lying around.
All is well and the brake works fine but I as surprised to find that in order to line the calliper up I had to use quite a lot of thick washers and shims between the fork and the brake mount.
I was surprised since I assumed everything (forks, hub, rotor, adapter, caliper) would be built to standard sizes.
Am I risking problems using the washers – there is probably about 2-3mm worth and the threads of the bolts do not completely engage the threads of the adapter (probably about 3/4 engaged).
