I have a Maxxis Minon DHR2 on the back. It has a small tear it in (can’t be more than a couple of mm long) but I think it’s been caused by hitting a rock, taking a small chunk out of the rim, just enough to cause a sharp burr, then dropping off something and it’s damaged the sidewall almost flush with the rim. It won’t seal. Or if it does stop leaking air, it only does it until any sideways pressure is put on it then it’s open again.
I don’t know if it can be patched at all with it that close to the bead, or if it’s just bin fodder. Or I just run with a tube in for the time being and take a few spares with me.
If it’s new tyre time (I much prefer tubeless now I’ve gone that route) what to replace it with? This’ll be the second Minion that’s died this way – the first one took a sharp rock to it midway up the sidewall – I’ve patched it inside and out but never tried to ride on it, and just bought a new one – reckon it’s worth trying?
These Maxxis tyres seem awfully fragile. It’s the 3C EXO version. I thought that was meant to be a bit more robust? Maybe not.
What’s a good alternative?
I’ll be paired with a DHF up front.
