Loads of bits before they go on ebay
photos available for all, just email me (email in profile)
Prices with postage is UK only
Open to offers on most of it -
SDG Formula FX I Beam saddle in White, the newer Edge Flex I-beam design, almost perfect, graphics starting to look a bit worn and a very tiny scuff on the back, otherwise good £45 posted ono
2x Halo Choir Master UST tyres, UST Folding bead, brand new unused still in boxes. RRP £35 but currently £21 each on CRC - http://www.chainreactioncycles.com/Models.aspx?PartnerID=79&ModelID=16351
£35 posted for the pair, or will split
Shimano Dura Ace bar end road shifters 3x9 with a bag of fittings for mounting on frame (thing everything is there but cant be sure)
Bought 2nd hand a few months ago but never fitted, cables are new but end is frayed (cut off or replace possibly), look good and have a smooth motion £40 posted ono
Shock Pump Not sure of brand but full alloy construction, brass fittings, braided hose, clear dial, pressure slow release button
As new, works fine just surplius as I have a Fox pump also £10 posted
Hope Mono Mini Reservoir caps (Pair) Black, (the newer shape) used but no major scratches, in boxes with bolts £6 posted the pair or will split
Avid Speed Dial SD1.9L V Brake levers Retro? Short two finger levers black and silver, lightweight, well marked around clamp areas but work well with reach adjust dials £12 posted the pair
Shimano DX SPD/Flat pedals PD M646 model - the original grey and black metal caged versions, cosmetically a little battered but work well, bearings etc all smooth and clips in and out fine, tension adjusters all ok etc - make me an offer
Hope brake mount adapter 'A' - IS to postmount 160 front or 140 rear - brand new unopened in bag - £6 posted
Hope brake mount adapter 'F' - IS rear to postmount 160 - brand new unopened in bag - £6 posted
See here for details of both mounts - http://www.hopegb.com/voir_hbm_image__tgrandeimage_1.html
Oakley GasCan Cystal Black w Black Iridium lenses
As new in box with documents and dustbag £45 posted (recorded)
Oakley Square Wire 30mm Gold with Bronze Iridium lenses
No marks or scratches (as new) in box (not the original box) with docs and dustbag, (around £130 new) - £60 posted (recorded)
Sram PG980 Cassette (11-34) used but prob has some life left in it yet, ideal on a 2nd or commuter / play bike maybe?
Black spider with lockring £7.50 posted ono
QR seat clamp fits 27.2mm seatpost (31.6mm clamp I thinK? Off a medium Commencal Meta - £3 posted
08/09 Commencal Meta or Supreme QR dropouts / mech hanger
2 sets available both used but fine
£12 each or both sets for £20 posted
Shimano XT (M760) Chainset and B/B
Cranks in great condition, only minor scuffing to noon driveside logo
Rings have some life left (44-32-22), bottom bracket good (some marks from removal tool - main issue is the bearing cover on one side has a minor crack but doesnt seem to affect it at all) New locking cap fitted £70 posted ono
