The Sq/ISIS Duo isn’t a specific chainset as such is it…
Middleburn only make 2 basic models of crank arm now – RS7 (Sq or ISIS) or RS8 X-Tyre (external BB) They’ve apparently discontinued the RS8 Sq/ISIS as the weight saving was no longer significant enough…
The “Duo” is simply an RS7 spider option, that special ring/spider attaches via the same splined interface any of their other spiders would.
I was suggesting you could just fit the standard “3 ring” 4 arm (104/64-BCD) spider with inner and middle position rings, and simply omit the outer position ring with shorter bolts (that’s what a lot of people have done in the past on various other 4 and 5 arm cranks) thus you’ve got your 2 x N chanset…
But obviously duo does look much neater and saves weight, I don’t think there’s a 4 bolt version of the duo ring/spider, the 3 bolt thing was partly about weight saving and partly about forcing compatibility, so Duo users only ever replace old middleburn rings with new middleburn rings (or get a different spider).
Duo rings
The thing is once you have bought the arms you can fit whatever combination of rings / spiders you fancy (within reason), just because you bought it as a Duo doesn’t mean it has to stay as one should you choose to go to single or triple rings in the future, if you buy an SLX or XT thought then you can only ever fit 104/64 BCD rings, for that reason alone the RS7 is a far more versatile option…
As an aside, if Middleburn were to do a Thick/Thin Uno ring, that would be a winner IMO…
