I’ve just fitted a 44 tooth Middleburn Slickshift Hardcoat ring to my M752 chainset in place of the original Shimano ring. It looks great but there’s a problem. In the middle ring and smallest (11 tooth) cog the chain catches the pins (Slickshift pins I reckon) of the Middleburn ring and make a lot of noise, backpedaling in the combination sometimes results in the chain catching on the pins and jamming or trying to derail. I had no such issues with the Shimano ring.
The Middleburn site states that the Hardcoat covering is 5 times thicker than normal anodizing so does this make the ring thicker causing the problem?
Any ideas for a solution?
