Clearing out my garage I came across my old two sets of Lupine Edisons that had failed. I bodged one set out of the remains but that also failed. Just before I throw them away I was trying to see if I could get anything working again.
The switch supplies voltage to the lamp ok. When I try to turn it on there is a dim flicker of light then nothing. Voltage at the lamp unit is 7.4v and t the terminals of the bulb itself.post starter it is 7.0v. When they were working they’d start with a much brighter flicker then dim before warming up for about 10s to reach full brightness.
The question is, is it possible that a component in the starter has failed, or is it more likely to be the lamp itself? Seem like the latter to me, but I’d like to know for sure. The starter is made of discrete components so could be fixable.
