The mighty berlingos making a racket.
Sounds like a wheel bearing when your driving. A howel nee grumble when you get upwards of 20mph any gear – neutral or clutch in also
No change when you turn
All wheels jacked up and seem in good fettle no play smooth and easy to turn.
How ever when I Jacked up near side and run the engine in first gear I can hear the growl. Sounds like it’s coming from the diff.
Did the same on other side. Same noise.
Checked gearbox oil . It was right height – so drained it and it was clean and no metal chips
Am I right in that it’ll most likely be the diff bearings or is there anything else in about there that could make that noise ?
Might be time to go car shopping. New gear box will run me 150 quid and if I’m in there I’ll change the clutch so that’s another 60 quid and I’m tight on time . Car needs to be back on road next Wednesday
It’s a 1.9d 5 speed box. Google seems to think the diffs replaceable on its own…. Any thoughts ?
