I have made a slight boo boo and can’t figure out a way to sort it. I had no idea this was going to be so heavy so i built it on it’s side for ease. I’d rather not take it apart again as building it upright is going to be V awkward. I could utilise a second body but it’s likely to be a week before any of my local mates are able to stop by, but i want to do this today.
So, can anyone think of a way this can be lifted upright by one man? The main posts are 12ft long x 100mm. The deadlift weight must be about 80kg as i find it quite a strain!
My wife could be called into play to position things.
There’s a tree stump around 45 degrees left of centre, and a cut tree trunk further left of that.
There’s also some side to side play that can result in it falling sideways if not supported well.
My first thought was to lift it and get my wife to put a wheelie bin under to hold it. Then get a hop-up platform and lift it a bit higher and get her to pop a ladder under, then get my platform ladder and lift more, bigger ladder under it etc.
You must know a neighbour? Anyway, it looks like once you get it past 30 degrees it’ll actually be pretty easy to lift thanks to the moment of the leg.
Easiest would be to go and get a few bodies to help. Simple job for 3 or 4 big chaps. Isn’t there anyone? Given the team you have lifting in stages, maybe with a lever, and propping it up (with your wife putting props in) is probably the simplest and safest
Turn it to face the stump then you can use that with some rope as a pull point, once it’s upright then walk it into place?
You will need rope at some point to control the descent – I think otherwise there’s a high risk of damage when it descends from the point of balance.
Be highly wary of lifting from a ladder for the obvious reasons – they are only designed for your weight, you’re doubling the load when you lift plus all sorts of offsetting load which will try to tip the ladder.
Hence the rope pull once you get some initial height under the cross beam.
If in doubt – give it a miss…
I’m not anything like fully brain functional yet but, attach weights to top of those diagonal beams and use the climbing frames to wedge under the crossbar? At some point in raising the crossbar, those weights (eg. bricks in sacks) will help lever the goalpost into an upright position.
You and wife get it raised slightly by hand and use poles/ lengths of timber to push on top horizontal piece to elevate? Maybe bit rope attached to it to slow it’s drop when vertical.
Just lift it and slide ever-larger objects under it. When it gets sufficiently high to get your car roof underneath, it should be easy to tip the rest of the way.
Or turn it slightly to the right, then drag a rope over your neighbour’s garage roof and pull from the garden three doors down.
Without another bod, trying to pull it up using the legs in the air will probably result in it twisting and damage.
Not entirely sure how this would work, but you could try anchoring a temporary section between the legs and using it as a fulcrum to try lift it alone. Anchor the other legs so i doesn’t slide, and it might just work.
Superb ideas. I like the thought of weights on the legs BUT they’ll encourage twisting. Not that the 10mm coach bolts are going to give up, but I’d like to keep strain on the wood to a minimum.
Greg, mates and beers would be the ideal choice, but mates are all working or busy with babies, basically just wrapped up in their own selfish lives just now 😉
Twonks I’d never have the strength to do it that way.
Can you do anything with a car trolley jack and some kind of additional platform? You might not need to raise it much to get to the point you can lift it the rest of the way yourself.
Set up a tripod with suitable length scaffold poles and attach the winch or block and tackle to the top. The trick will be to put the tripod together and you may need another to get that into place 😉
Could you give your location and see if you can gather enough STWers to join you for a lifting party?
Suspect you are a little far north for me to help…
stepladder alongside top beam. lift it a couple of steps in height, tie it off, push step ladder in, untie and lift next couple of steps – repeat. Once at full height of step ladder it should be high enough that you can push one of the legs to do the final tip over
Normally you have to dig the legs of these things in a bit rather than just sit on the ground. did you not have to do that?
It’s going to be nasty when you get it over the high point and gravity tries to take over. Take the far end off, and brace the other. Get lots of ropes, a pulley or three, and stakes to use the spare pair as shear legs. Note that they are prone to falling backwards if it all goes tango uniform. That’s what a lot of the rope and stakes are to prevent.
Get the bulk of it up as a wonky tripod, move your shear legs to lift the crossbar. Then comes the tricky bit of supporting the crossbar while you sort the supports back underneath it.
Lifting it is the easy half of the problem- you will need to catch it as it comes upright to stop it falling (and maybe toppling right over again). Minimum 4 blokes, I would say: one each end to lift and walk the legs up and two on the other side to take the opposide legs as they come down again.
If it’s bolted together, just dismantle it and reassemble in the correct orientation! 🙂
(A frames first, lying flat; join top beam to one A frame as a tripod; bring 2nd A frame upright under the top beam, lifting it to horizontal in the process.)
I’d try lifting one end up a little and getting my wife to place the first or second step of the step ladder under it. Do the same the other end and walk it up to as high as you can manage. Once it’s a decent height I’d right a block and tackle to pull it upright.
H&S, what’s that 😮 Failing that ask some neighbours or passers by. More often than not they’re willing to help.
I’d opt for your plan of lifting and propping a bit at a time if you can’t cadge anyone to give a hand. Would add a rope to catch it as you get past the balance point, tied so that you can lower the far legs down.
Actually, I’d use the timber crane on the tractor, but I’m guessing you don’t have one as it would have been upright by now otherwise.
