Viewing 36 posts - 1 through 36 (of 36 total)
  • Maxxis Tyres – Which one for general all round ?
  • COZZY
    Hi All
    I havnt tried Maxxis tyres before but am going to get some
    – but there are soooo many and I wont have the budget to keep changing for seasons- so are is there “the one” decent all rounder tyre for the weekend warrior ?
    BadlyWiredDog
    What sort of size? Where do you mostly ride?
    MoseyMTB
    I’m a big fan of Ardent’s.
    I’ve had high rollers and minions but always come back to Ardent.
    mrblobby
    Minion Rear on the front and High roller on the back is the classic gnarr combination and works very well. If it’s dryer and you want something faster rolling them a Larsen on the back works well. Lots of people seem to like the Advantage too.
    tomaso
    If you ride on the South Downs or Mendips or Cwm Carn or Torridon etc different tyres will work better for each.
    And how you ride and what you like or value will also determine choice.
    I’d go big fat dual ply high rollers and minions but you may not want to haul 1.3kg of tyre round each hoop.
    BadlyWiredDog
    My year-round combo, mostly in the Peak is a 2.5 Minion DHF – more like a big 2.35 from most brands – and a 2.25 Ardent, which is almost as big, on the back, both EXO versions with the tougher sidewall. Ardent’s are great rear tyres, but a bit iffy up front on softer stuff unless you’re using the 2.4 which has bigger lugs for some reason.
    But as above, it all depends on how and where you ride.
    crush83
    I run HR2 2.4 exo front and rear and they cope with everything! Dry trails to snow
    eskay
    I run Ignitors all year round.
    fasthaggis
    I run an Ignitor/Advantage combo all year round 🙂
    Euro
    I can’t be arsed with all the tyre swapping nonsense either so single ply high rollers with good old fashioned tubes (supertacky front/harder rear) do it for me. I appreciate this combo might not work for everyone. If you ride like a gorilla you might pinch flat everywhere but i’m smooth like butter and never ever stutter…
    tomaso
    I don’t stutter but I ain’t smooth like butter :mrgreen:
    Self portait of me pondering tyres
    tuffty
    I too can’t be arsed changing tyres so have advantage 2.25 on front and rear.
    chum3
    Used Advatanges 2.25s for years on my 140mm FS. Swapped to High Roller on the front on a recommendation, but slightly preferred the predictable, progressive grip of the ADs on balance, even if the HR had a bit more ultimate grip. Suited my riding better I think…
    Heard good things about the HR2, which I haven’t tried.
    Pawsy_Bear
    High roller 2.3 LUST front Ardent 2.25 rear. Grat combo for all year fit and forget
    ds3000
    Ardent 2.4 front and Beaver rear on my swift suit me sir all year round.
    nuke
    Tried a few and like Ignitor front, Advantage/Ardent rear but I’ve settled on Minion 2.35 front, OnOne Smorgasbord 2.25 rear (Still fits the OPs question as iirc Maxxis make the On-One tyres 🙂 ). For more AM stuff, Minion 2.5 front, OnOne Chunky Monkey 2.4 rear
    stevied
    Very happy with my 2.5″ Minion DHF exo front, 2.3″ High Roller 2 exo rear. Maybe not the fastest rolling but I run them all year round. Got the exo for a bit more sidewall protection as I run tubeless..
    COZZY
    Many thanks to all for all the advice.
    I will decide from the replies and see who does the best deals.
    I was going to back to 2.1 max but you guys ride wider so maybe I’ll follow suit ?
    Thanks again.
    COZZY
    My riding is xc and trail riding.
    Chiltern loops – ridgeway loops – swinley and trail centres
    Not dh.
    mikewsmith
    ardents for 18 months now with a brief return to HRII’s for Gravity in Rotorua
    It is however much drier here in Tasmania!
    Before that minions all round in the lakes.
    Tried the mythical HR/Minion combo but hated the fact that they profile’s were different (round vs square) and the bite point on the lean was very different)
    zelak999
    I’m loving the new High Roller 2.3 TR.
    Fast rolling and good grip in all conditions.
    dbukdbuk
    Can’t say I’ve tried many but currently running Ardent LUST on my bouncy bike. They seem to work just fine for me. Had the regular Ardents before that but found the sidewalls a bit fragile.
    erny
    Agree with zelak the high roller 2 TR 2.3’s are really good, I got mine from nextdaytyres
    rOcKeTdOg
    Spring/Autumn-ardent
    Summer-ardentF crossmarkR
    Winter-beaver
    ndthornton
    So basically for every tyre there is a lover and a hater.
    For the record I just ordered some ardents- on what basis…..
    A similar thread to this
    Probably make bog all difference but I wanted something to roll better than my Hans dampf. Reality is im probably just week and inadequate
    ndthornton
    Winter-beaver
    My GF has one of those- trims it in the spring
    COZZY
    Ndthornton-
    Haha – yeah I’m after those magic ones that roll like slicks but stick like glue – and cut through and make the muddy hill climbs a breeze – but it could be me also…
    What size ardents- did you go for ?
    chiefgrooveguru
    Something that rolls well in the dry and still gets up the hills in the mud doesn’t really exist! It doesn’t cost anymore to have a winter set and summer set because they’ll last longer, than riding the same tyres year round. Mud tyres wear out much quicker in the dry than in the mud too, so it should cost less if you’re erring on the side of being able to pedal up muddy hills. Bontrager XR-Mud or Maxxis Beavers are probably your best bet for the wetter seasons and then Ardents or similar for the drier times (day?)
    ndthornton
    2.4 on the front
    2.25 on the back
    Iv heard the 2.25 are pretty big so god knows what the 2.4 will be like!
    bomberman
    Cozzy i run folding maxxis high rollers front and rear in a 2.3 style (lighter in folding), then when the weather gets better i swap the back for a kenda small block 8. There’s a massive difference in rolling resistance and the small block is surprisingly grippy in all conditions except bad mud, so it usually stays on most of the year.
    If you haven’t tried a small block 8 i would definitely recommend it for when the trails dry out a bit, it’s fast and grippy.
    rob-jackson
    On-one chunky monkey front and rear – maxxis tyres with exo sidewalls (sorry eckso) but at one one prices, or swap for smorgasbords
    cfinnimore
    2.35 Dhf 60a on front and 2.35 40a high roller on back.
    people say the dhf width isn’t 2.35 but it’s the grippiest front tyre I’ve ever had.
    It must be beyond sticky in the soft compound.
    jairaj
    Another Ignitor user here. Use them all year round for all kinds of riding from long xc rides to messing about on jumps and even DH. Absolutely love them.
    chiefgrooveguru
    You must be the only person ever to deliberately run a 60a up front but a super tacky (or is it the even stickier one with the silly name?) on the back!
    FROGLEEK
    minion dhf super tacky 2.5
    high roller II 60a rear
    perfect for welsh slop at the mo
    come summer I might even keep them on!
    FROGLEEK
    high roller II in 2.4 btw
The topic ‘Maxxis Tyres – Which one for general all round ?’ is closed to new replies.
