The OEM-spec nevegals are rubbish, the aftermarket ones are a totally different tyre (different carcass and compounds). Really stupid behaviour from Kenda, that, gives them a bad name.
I like Nevegals, prefer them to my Minions for most use- they’re a bit more neutral handling and consistent. Got to be a stick-e for the front though, the DTC always feels “pingy” as if it’s overinflated, it wants to bounce off things not track over them.
Both have their advantages but to me, the Minion’s only better when pushed very hard, the edge grip definately has the Nevegal beat but the mid-lean grip seems much less inspiring, they either want to be upright or leaned right over I reckon. And the weight and rolling resistance is much higher. (*)
I always feel like I need to be riding like a nutter for the Minions to really work properly and on unfamiliar trails or longer rides I just can’t put down that sort of commitment often enough to make them shine. And if I’m off the boil they feel unpredictable, whereas the Nevegal delivers better performance for that 90% of the time. Realistically most of my riding needs a more balanced tyre. But more awesome riders might disagree 😉
(* when talking about these tyres you have to bear in mind that the 2.35 Nevegal is accurately sized while the 2.35 Minion is very undersized- the 2.35 Nev’s almost exactly as wide as the 2.5 Maxxis)
If you’re at all unsure you really can’t go too far wrong with a Highroller or a Minion tbh, the worst that’ll happen is it’s heavier and draggier than you need but you won’t often feel like you’re short of tyre.
