I havent tried this combo before so im wondering if any of you have experience of running single ply dhfs on xt tubeless wheels at all? Or any of the other shimano tubeless rims? I take it the correct amount of stans fluid would be the safest way to go but has anyone found they could get away with less than recommended or needed a bit more?
Also wondering how well it stays on the rim around 25psi compared to the likes of a proper tubeless tyre under hard cornering in burpy moments. Stans is the fluid i would probably be using but open to any other suggestions... other than that pink zefal strawberry milkshake stuff!
thanks
Martin
