Viewing 2 posts - 1 through 2 (of 2 total)
  • Maxle lever, stuck in the 'open' position
  • codybrennan
    Weird one- first ride on a new bike yesterday. End of the ride, removed the front wheel as normal from the Recon Solo Air fork, loaded up the bike, put the maxle in my bag with the lever in the ‘open’ position.
    Got home, went to reinstall the wheel, maxle went in ok- but the lever is stuck open- hmm. Even pushing it gently to see if its just a bit sticky has no effect at all, it seems completely jammed.
    Any thoughts?
    it looks like this (not the same exact model as mine)
    lycanthropefailed
    Probably a different model, but mine has a quick release type screw on thingy at the other end. If it gets screwed in a bit it gives the same symptoms as you describe.
The topic ‘Maxle lever, stuck in the 'open' position’ is closed to new replies.
