I've got the following up for grabs :
Easton EA50 seatpost - 350mm- 30.9 - ok condition, but the anodizing has rubbed off - 10 quid posted. (used to look like this, but now the logos have been worn away - photobucket is being an arse, so I can't upload new pics at the moment...)
FSA FR 200 seatpost - again 350mm is 31.6 . - good condition, with the usual scratches that you'd expect - 15 quid posted.
Specalized hoffilizer tyre, 1.8, very good condition - loads of tread left - 10 quid posted.
Pair of Mavic Crossride wheels - dual disc / rim use. Good condition - have been only really been used as my comuting wheels for about a year or so. The rear has been stripped down, and reassembled with a new paw / spring as they were sticking, but they are fine now.. Not completely true, but noting really noticable (but would rather be honest!) will sell with the Advantage tyres - part worn (rear more so than the front) for £110 posted:
Reba forks - in need of a service - pics per the below - am after £80 posted for these - basically, i expect they just need to be srtipped, have the seals replaced (as a matter of course), and to be re-filled with oil!
They were used offroad for a bit, but were then just used on my commuting bike for the best part of 2 years. The suspension does still work, its just spongey, hence me recomending the above!
Xt front mech (34.9)£12 posted each
And last but not least, I've got 2 XT chainsets.
On one - the bottom bracket needs replacing as the bearings have a fair bit of play - there is a little wear to the rings, but nothing major - a few teeth on the big ring are worn due to rocks in verbier
On the second, i'm unsure of the BB, but would assume it needs replacing also. The rings on this are fairly worm (was used to commute on, so the middle, and granny ring are actually probabaly ok) - oh, one of the chainring bolts is missing too...
Don't really know what these are worth - say 80 quid for the better of the 2, and 40 quid for the other? - (although open to offers as I don't havea clue what they're actually worth!) - pics below: (better of the 2 is on the left, and if the first pic of the rings)
If you've got any questions etc, then please email me:
richard dot wise at shell dot com - i don't get to check here as often as i would like.
Thanks,
Rich
