Just got a set of these rims to lace up to some ProII Evo hubs – look to be very nice (weight is exactly 450g as stated + the Mavic cups)
What I’m struggling with is figuring out the spoke length as the Mavic calculator (which uses hub hole diameter & flange to fork/frame support distance and hides things such as the ERD and offset) is throwing up the following numbers:
Front Non-Drive = 258.36mm
Front Drive = 259.97mm
Rear Non-Drive = 259.45mm
Rear Drive = 258.61mm
This is different to what both Moonglu and bbb have listed as the spoke length so I’m wondering where to go with this? The offset design means it’s difficult to use standard calculators.
Thanks
