if the bushing is worn down, buy a new one from ebay! freehub is simple to remove.
-pull of non-drive side axle cap with pliers
8mm hex wrench in non-drive side, 5mm in drive side the undo
carefully!! remove freehub paying attention to the pawl springs that might spring out.
-also do not lose the washer which is inside the freehub, this rests inside and between the freehub and axle.
-clean freehub and pawls with rubbing alchohol the apply light oil to ratchets and pawls-dont go mad!
if your cassette is wobbling on the freehub then the bushing will need to be replaced-look on ebay.
-when ready to replace:place washer ontop of axle with a little grease, push pawls in and gently slide the freehub down and fit into place.
-8mm,5mm hex wrenches again to tighten up. about 70nm, quite tight!
good luck
