I have had a ML7.5 for 3 years and love it. Every time I ride it it stuns me.
It has suspension action but puts the power down effeciently with no bob. It does this without a fancy shock (most suspension bikes need shocks with masses of low speed compression damping, Colin Chapman once said you can make any suspension work if you dont let it work……) The grip is amazing. In granny gear climbs it just keeps going.
The frame is one of the most structurally effecient I have seen, with major loads going into tube junctions and not the middle of tubes. The deisgn is a simple triangle which is why it is so light.
My experience of Maverick customer service has been fantastic.
A friend rode it and was stunned. He had researched bikes and tried many but had never heard on Maverick. He tried mine and wondered why it was not in all the magazines as the perfect bike.
The bent seat tube and excessive layback of the seat tube (use a lay back point forwards…) are compromises. I also dont like the integrated head set because I cant fit a Chris King.
People mention about the suspension stiffening when you stand. It does but only slightly. This is due to the angle of the link and the position of the bottom bracket in relation to the rear pivot. The leverage is quite small. I actually think the suspension stiffening slightly is a good thing as when you are standing the legs can take the slight increase in bumps. However you will soon realise you can just sit down and pedal over stuff with fantastic traction.
The other thing you will have to put up with is doubters who cant believe or dont want to believe the bikes are so good. Ignore them, enjoy the ride and welcome to Maverick.
