I've just serviced Juans forks. No problems doing it, I just took them apart, removed the air and damping cartridges, relubed them and changed the damping oil, then put them all backtogether again. I DID NOT open up the Doppio air cartidge
Anyway, I've got hold of an air adaptor so I can pump them back up, and had a look on the net for set up advice, but I can't get anyhwhere near the given pressures for my weight as the spring is basically rock hard at those pressures. I think I have around 50psi in them at the minute
AND they have the harshest top-out clunk you can imagine! I've slowed the rebound down which has no effect on the clunk
When Juan gave them to me they were sitting right down into their travel at maybe 100-120mm, so they didn't top out. I've now got the full 150mm showing.
They don't feel too bad to ride, a lot smoother than before, but something isn't right somewhere.
Any ideas?
