In a similar situation here. I actually contacted Windwave yesterday – they’re really helpful. There isn’t a hard spring available for these forks unfortunately.
Echo what most people say here – adding air solves the diving problem but loses sensitivity a bit. Doc here suggests you should be at about 20psi:
Manual
I’ve also found that if you add air to stop the diving, it’s hard to get full travel.
Also worth whacking the mechanical preload on the LH leg up to max before adding air to see if that will help.
Have also heard that changing to 10wt helps or mix 7.5wt and 10wt to get somewhere in between can help.
Good luck!
