Hmm I’m not sure the Zocci strategy is a bad thing.
The only new fork technologies that seem worth having are dual-ported rebound and compression circuits that allow the rider to adjust high and low speed compression and rebound independently. These are fairly straightforward and usually use shim stacks, sometimes externally-adjustable shim stacks.
A 20mm bolt through, open bath damped fork with adjustable rebound and compression shim stacks, coil spring, decent seals, available in 140mm and beefed up 160mm versions, 2Kg ish weight would be a fantastic fork.
Things like pneumatic travel adjust (Talas, 2 step etc) aren’t reliable and just add extra seals to go pop.
